Fixture request - repair MagVader fan
Hello,
the fixture MagVader from Licht Technik have a Fan defined with valus 0-11% in the user range.
Don't make any sense. Every time i like to use them i need to remind myself to alter the fan manualy.
Can it be repaired in the library that the range is 0-100?
Thanks a lot
thilda
  • FYI in the short term you can edit your personal version.
    Copy the current version of the profile (find the fixtures softkey in patch), then you can change whatever you like.
    This profile can be saved in a 'template' file (if you don't use one, now is a good time to start) or merged into other files as you want.
  • Hi Mathilda,
    Do you happen to have a copy of the fixture's manual and DMX chart that I can reference when troubleshooting this profile. Additionally, what Eos fixture library build are you currently running? Thank you!
    Best,
    Therese
  • Sorry Therese for beeing late.
    You can find the manual at:
    http://www.licht-technik.com/download/MagVader/MV_eng.pdf
    There is no real dmx chart. But find information about the fan at page 38.
    I run the standard fixture lib from v2.8.3
  • Hi Mathilda,
    Thank you for the documentation. Cross referencing this manual with the current Eos fixture library I see that we have numerous MagVader profiles. Can you tell me which profile/mode is giving you issue?
    MagVader 175E Scrl0 Shtr0 4 MagVader 175 Event Scroller m0 - Shutter m0 - Fan off; MV175
    Licht Technik MagVader 175E Scrl0 Shtr0 Fan 5 MagVader 175 Event Scroller m0 - Shutter m0 - Fan on; MV175
    Licht Technik MagVader 175E Scrl0 Shtr1 4 MagVader 175 Event Scroller m0 - Shutter m1 - Fan off; MV175
    Licht Technik MagVader 175E Scrl0 Shtr1 Fan 5 MagVader 175 Event Scroller m0 - Shutter m1 - Fan on; MV175
    Licht Technik MagVader 175E Scrl0 Shtr2 4 MagVader 175 Event Scroller m0 - Shutter m2 - Fan off; MV175
    Licht Technik MagVader 175E Scrl0 Shtr2 Fan 5 MagVader 175 Event Scroller m0 - Shutter m2 - Fan on; MV175
    Licht Technik MagVader 175E Scrl0 Shtr3 3 MagVader 175 Event Scroller m0 - Shutter m3 - Fan off; MV175
    Licht Technik MagVader 175E Scrl0 Shtr3 Fan 4 MagVader 175 Event Scroller m0 - Shutter m3 - Fan on; MV175
    Licht Technik MagVader 175E Scrl1 Shtr0 4 MagVader 175 Event Scroller m1 - Shutter m0 - Fan off; MV175
    Licht Technik MagVader 175E Scrl1 Shtr0 Fan 5 MagVader 175 Event Scroller m1 - Shutter m0 - Fan on; MV175
    Licht Technik MagVader 175E Scrl1 Shtr1 4 MagVader 175 Event Scroller m1 - Shutter m1 - Fan off; MV175
    Licht Technik MagVader 175E Scrl1 Shtr1 Fan 5 MagVader 175 Event Scroller m1 - Shutter m1 - Fan on; MV175
    Licht Technik MagVader 175E Scrl1 Shtr2 4 MagVader 175 Event Scroller m1 - Shutter m2 - Fan off; MV175
    Licht Technik MagVader 175E Scrl1 Shtr2 Fan 5 MagVader 175 Event Scroller m1 - Shutter m2 - Fan on; MV175
    Licht Technik MagVader 175E Scrl1 Shtr3 3 MagVader 175 Event Scroller m1 - Shutter m3 - Fan off; MV175
    Licht Technik MagVader 175E Scrl1 Shtr3 Fan 4 MagVader 175 Event Scroller m1 - Shutter m3 - Fan on; MV175
    Licht Technik MagVader 175E Scrl2 Shtr0 3 MagVader 175 Event Scroller m2 - Shutter m0 - Fan off; MV175
    Licht Technik MagVader 175E Scrl2 Shtr0 Fan 4 MagVader 175 Event Scroller m2 - Shutter m0 - Fan on; MV175
    Licht Technik MagVader 175E Scrl2 Shtr1 3 MagVader 175 Event Scroller m2 - Shutter m1 - Fan off; MV175
    Licht Technik MagVader 175E Scrl2 Shtr1 Fan 4 MagVader 175 Event Scroller m2 - Shutter m1 - Fan on; MV175
    Licht Technik MagVader 175E Scrl2 Shtr2 3 MagVader 175 Event Scroller m2 - Shutter m2 - Fan off; MV175
    Licht Technik MagVader 175E Scrl2 Shtr2 Fan 4 MagVader 175 Event Scroller m2 - Shutter m2 - Fan on; MV175
    Licht Technik MagVader 175E Scrl2 Shtr3 2 MagVader 175 Event Scroller m2 - Shutter m3 - Fan off; MV175
    Licht Technik MagVader 175E Scrl2 Shtr3 Fan 3 MagVader 175 Event Scroller m2 - Shutter m3 - Fan on; MV175
    Licht Technik MagVader 200 Scrl0 Shtr0 4 MagVader 200 Scroller m0 - Shutter m0 - Fan off; MV200
    Licht Technik MagVader 200 Scrl0 Shtr0 Fan 5 MagVader 200 Scroller m0 - Shutter m0 - Fan on; MV200
    Licht Technik MagVader 200 Scrl0 Shtr1 4 MagVader 200 Scroller m0 - Shutter m1 - Fan off; MV200
    Licht Technik MagVader 200 Scrl0 Shtr1 Fan 5 MagVader 200 Scroller m0 - Shutter m1 - Fan on; MV200
    Licht Technik MagVader 200 Scrl0 Shtr2 4 MagVader 200 Scroller m0 - Shutter m2 - Fan off; MV200
    Licht Technik MagVader 200 Scrl0 Shtr2 Fan 5 MagVader 200 Scroller m0 - Shutter m2 - Fan on; MV200
    Licht Technik MagVader 200 Scrl0 Shtr3 3 MagVader 200 Scroller m0 - Shutter m3 - Fan off; MV200
    Licht Technik MagVader 200 Scrl0 Shtr3 Fan 4 MagVader 200 Scroller m0 - Shutter m3 - Fan on; MV200
    Licht Technik MagVader 200 Scrl1 Shtr0 4 MagVader 200 Scroller m1 - Shutter m0 - Fan off; MV200
    Licht Technik MagVader 200 Scrl1 Shtr0 Fan 5 MagVader 200 Scroller m1 - Shutter m0 - Fan on; MV200
    Licht Technik MagVader 200 Scrl1 Shtr1 4 MagVader 200 Scroller m1 - Shutter m1 - Fan off; MV200
    Licht Technik MagVader 200 Scrl1 Shtr1 Fan 5 MagVader 200 Scroller m1 - Shutter m1 - Fan on; MV200
    Licht Technik MagVader 200 Scrl1 Shtr2 4 MagVader 200 Scroller m1 - Shutter m2 - Fan off; MV200
    Licht Technik MagVader 200 Scrl1 Shtr2 Fan 5 MagVader 200 Scroller m1 - Shutter m2 - Fan on; MV200
    Licht Technik MagVader 200 Scrl1 Shtr3 3 MagVader 200 Scroller m1 - Shutter m3 - Fan off; MV200
    Licht Technik MagVader 200 Scrl1 Shtr3 Fan 4 MagVader 200 Scroller m1 - Shutter m3 - Fan on; MV200
    Licht Technik MagVader 200 Scrl2 Shtr0 3 MagVader 200 Scroller m2 - Shutter m0 - Fan off; MV200
    Licht Technik MagVader 200 Scrl2 Shtr0 Fan 4 MagVader 200 Scroller m2 - Shutter m0 - Fan on; MV200
    Licht Technik MagVader 200 Scrl2 Shtr1 3 MagVader 200 Scroller m2 - Shutter m1 - Fan off; MV200
    Licht Technik MagVader 200 Scrl2 Shtr1 Fan 4 MagVader 200 Scroller m2 - Shutter m1 - Fan on; MV200
    Licht Technik MagVader 200 Scrl2 Shtr2 3 MagVader 200 Scroller m2 - Shutter m2 - Fan off; MV200
    Licht Technik MagVader 200 Scrl2 Shtr2 Fan 4 MagVader 200 Scroller m2 - Shutter m2 - Fan on; MV200
    Licht Technik MagVader 200 Scrl2 Shtr3 2 MagVader 200 Scroller m2 - Shutter m3 - Fan off; MV200
    Licht Technik MagVader 200 Scrl2 Shtr3 Fan 3 MagVader 200 Scroller m2 - Shutter m3 - Fan on; MV200
    Licht Technik MagVader 250 Scrl0 Shtr0 4 MagVader 250 Scroller m0 - Shutter m0 - Fan off; MV250
    Licht Technik MagVader 250 Scrl0 Shtr0 Fan 5 MagVader 250 Scroller m0 - Shutter m0 - Fan on; MV250
    Licht Technik MagVader 250 Scrl0 Shtr1 4 MagVader 250 Scroller m0 - Shutter m1 - Fan off; MV250
    Licht Technik MagVader 250 Scrl0 Shtr1 Fan 5 MagVader 250 Scroller m0 - Shutter m1 - Fan on; MV250
    Licht Technik MagVader 250 Scrl0 Shtr2 4 MagVader 250 Scroller m0 - Shutter m2 - Fan off; MV250
    Licht Technik MagVader 250 Scrl0 Shtr2 Fan 5 MagVader 250 Scroller m0 - Shutter m2 - Fan on; MV250
    Licht Technik MagVader 250 Scrl0 Shtr3 3 MagVader 250 Scroller m0 - Shutter m3 - Fan off; MV250
    Licht Technik MagVader 250 Scrl0 Shtr3 Fan 4 MagVader 250 Scroller m0 - Shutter m3 - Fan on; MV250
    Licht Technik MagVader 250 Scrl1 Shtr0 4 MagVader 250 Scroller m1 - Shutter m0 - Fan off; MV250
    Licht Technik MagVader 250 Scrl1 Shtr0 Fan 5 MagVader 250 Scroller m1 - Shutter m0 - Fan on; MV250
    Licht Technik MagVader 250 Scrl1 Shtr1 4 MagVader 250 Scroller m1 - Shutter m1 - Fan off; MV250
    Licht Technik MagVader 250 Scrl1 Shtr1 Fan 5 MagVader 250 Scroller m1 - Shutter m1 - Fan on; MV250
    Licht Technik MagVader 250 Scrl1 Shtr2 4 MagVader 250 Scroller m1 - Shutter m2 - Fan off; MV250
    Licht Technik MagVader 250 Scrl1 Shtr2 Fan 5 MagVader 250 Scroller m1 - Shutter m2 - Fan on; MV250
    Licht Technik MagVader 250 Scrl1 Shtr3 3 MagVader 250 Scroller m1 - Shutter m3 - Fan off; MV250
    Licht Technik MagVader 250 Scrl1 Shtr3 Fan 4 MagVader 250 Scroller m1 - Shutter m3 - Fan on; MV250
    Licht Technik MagVader 250 Scrl2 Shtr0 3 MagVader 250 Scroller m2 - Shutter m0 - Fan off; MV250
    Licht Technik MagVader 250 Scrl2 Shtr0 Fan 4 MagVader 250 Scroller m2 - Shutter m0 - Fan on; MV250
    Licht Technik MagVader 250 Scrl2 Shtr1 3 MagVader 250 Scroller m2 - Shutter m1 - Fan off; MV250
    Licht Technik MagVader 250 Scrl2 Shtr1 Fan 4 MagVader 250 Scroller m2 - Shutter m1 - Fan on; MV250
    Licht Technik MagVader 250 Scrl2 Shtr2 3 MagVader 250 Scroller m2 - Shutter m2 - Fan off; MV250
    Licht Technik MagVader 250 Scrl2 Shtr2 Fan 4 MagVader 250 Scroller m2 - Shutter m2 - Fan on; MV250
    Licht Technik MagVader 250 Scrl2 Shtr3 2 MagVader 250 Scroller m2 - Shutter m3 - Fan off; MV250
    Licht Technik MagVader 250 Scrl2 Shtr3 Fan 3 MagVader 250 Scroller m2 - Shutter m3 - Fan on; MV250
    Licht Technik MagVader 300 Scrl0 Shtr0 4 MagVader 300 Scroller m0 - Shutter m0 - Fan off; MV300
    Licht Technik MagVader 300 Scrl0 Shtr0 Fan 5 MagVader 300 Scroller m0 - Shutter m0 - Fan on; MV300
    Licht Technik MagVader 300 Scrl0 Shtr1 4 MagVader 300 Scroller m0 - Shutter m1 - Fan off; MV300
    Licht Technik MagVader 300 Scrl0 Shtr1 Fan 5 MagVader 300 Scroller m0 - Shutter m1 - Fan on; MV300
    Licht Technik MagVader 300 Scrl0 Shtr2 4 MagVader 300 Scroller m0 - Shutter m2 - Fan off; MV300
    Licht Technik MagVader 300 Scrl0 Shtr2 Fan 5 MagVader 300 Scroller m0 - Shutter m2 - Fan on; MV300
    Licht Technik MagVader 300 Scrl0 Shtr3 3 MagVader 300 Scroller m0 - Shutter m3 - Fan off; MV300
    Licht Technik MagVader 300 Scrl0 Shtr3 Fan 4 MagVader 300 Scroller m0 - Shutter m3 - Fan on; MV300
    Licht Technik MagVader 300 Scrl1 Shtr0 4 MagVader 300 Scroller m1 - Shutter m0 - Fan off; MV300
    Licht Technik MagVader 300 Scrl1 Shtr0 Fan 5 MagVader 300 Scroller m1 - Shutter m0 - Fan on; MV300
    Licht Technik MagVader 300 Scrl1 Shtr1 4 MagVader 300 Scroller m1 - Shutter m1 - Fan off; MV300
    Licht Technik MagVader 300 Scrl1 Shtr1 Fan 5 MagVader 300 Scroller m1 - Shutter m1 - Fan on; MV300
    Licht Technik MagVader 300 Scrl1 Shtr2 4 MagVader 300 Scroller m1 - Shutter m2 - Fan off; MV300
    Licht Technik MagVader 300 Scrl1 Shtr2 Fan 5 MagVader 300 Scroller m1 - Shutter m2 - Fan on; MV300
    Licht Technik MagVader 300 Scrl1 Shtr3 3 MagVader 300 Scroller m1 - Shutter m3 - Fan off; MV300
    Licht Technik MagVader 300 Scrl1 Shtr3 Fan 4 MagVader 300 Scroller m1 - Shutter m3 - Fan on; MV300
    Licht Technik MagVader 300 Scrl2 Shtr0 3 MagVader 300 Scroller m2 - Shutter m0 - Fan off; MV300
    Licht Technik MagVader 300 Scrl2 Shtr0 Fan 4 MagVader 300 Scroller m2 - Shutter m0 - Fan on; MV300
    Licht Technik MagVader 300 Scrl2 Shtr1 3 MagVader 300 Scroller m2 - Shutter m1 - Fan off; MV300
    Licht Technik MagVader 300 Scrl2 Shtr1 Fan 4 MagVader 300 Scroller m2 - Shutter m1 - Fan on; MV300
    Licht Technik MagVader 300 Scrl2 Shtr2 3 MagVader 300 Scroller m2 - Shutter m2 - Fan off; MV300
    Licht Technik MagVader 300 Scrl2 Shtr2 Fan 4 MagVader 300 Scroller m2 - Shutter m2 - Fan on; MV300
    Licht Technik MagVader 300 Scrl2 Shtr3 2 MagVader 300 Scroller m2 - Shutter m3 - Fan off; MV300
    Licht Technik MagVader 300 Scrl2 Shtr3 Fan 3 MagVader 300 Scroller m2 - Shutter m3 - Fan on; MV300
    Licht Technik MagVader 350 Scrl0 Shtr0 4 MagVader 350 Scroller m0 - Shutter m0 - Fan off; MV350
    Licht Technik MagVader 350 Scrl0 Shtr0 Fan 5 MagVader 350 Scroller m0 - Shutter m0 - Fan on; MV350
    Licht Technik MagVader 350 Scrl0 Shtr1 4 MagVader 350 Scroller m0 - Shutter m1 - Fan off; MV350
    Licht Technik MagVader 350 Scrl0 Shtr1 Fan 5 MagVader 350 Scroller m0 - Shutter m1 - Fan on; MV350
    Licht Technik MagVader 350 Scrl0 Shtr2 4 MagVader 350 Scroller m0 - Shutter m2 - Fan off; MV350
    Licht Technik MagVader 350 Scrl0 Shtr2 Fan 5 MagVader 350 Scroller m0 - Shutter m2 - Fan on; MV350
    Licht Technik MagVader 350 Scrl0 Shtr3 3 MagVader 350 Scroller m0 - Shutter m3 - Fan off; MV350
    Licht Technik MagVader 350 Scrl0 Shtr3 Fan 4 MagVader 350 Scroller m0 - Shutter m3 - Fan on; MV350
    Licht Technik MagVader 350 Scrl1 Shtr0 4 MagVader 350 Scroller m1 - Shutter m0 - Fan off; MV350
    Licht Technik MagVader 350 Scrl1 Shtr0 Fan 5 MagVader 350 Scroller m1 - Shutter m0 - Fan on; MV350
    Licht Technik MagVader 350 Scrl1 Shtr1 4 MagVader 350 Scroller m1 - Shutter m1 - Fan off; MV350
    Licht Technik MagVader 350 Scrl1 Shtr1 Fan 5 MagVader 350 Scroller m1 - Shutter m1 - Fan on; MV350
    Licht Technik MagVader 350 Scrl1 Shtr2 4 MagVader 350 Scroller m1 - Shutter m2 - Fan off; MV350
    Licht Technik MagVader 350 Scrl1 Shtr2 Fan 5 MagVader 350 Scroller m1 - Shutter m2 - Fan on; MV350
    Licht Technik MagVader 350 Scrl1 Shtr3 3 MagVader 350 Scroller m1 - Shutter m3 - Fan off; MV350
    Licht Technik MagVader 350 Scrl1 Shtr3 Fan 4 MagVader 350 Scroller m1 - Shutter m3 - Fan on; MV350
    Licht Technik MagVader 350 Scrl2 Shtr0 3 MagVader 350 Scroller m2 - Shutter m0 - Fan off; MV350
    Licht Technik MagVader 350 Scrl2 Shtr0 Fan 4 MagVader 350 Scroller m2 - Shutter m0 - Fan on; MV350
    Licht Technik MagVader 350 Scrl2 Shtr1 3 MagVader 350 Scroller m2 - Shutter m1 - Fan off; MV350
    Licht Technik MagVader 350 Scrl2 Shtr1 Fan 4 MagVader 350 Scroller m2 - Shutter m1 - Fan on; MV350
    Licht Technik MagVader 350 Scrl2 Shtr2 3 MagVader 350 Scroller m2 - Shutter m2 - Fan off; MV350
    Licht Technik MagVader 350 Scrl2 Shtr2 Fan 4 MagVader 350 Scroller m2 - Shutter m2 - Fan on; MV350
    Licht Technik MagVader 350 Scrl2 Shtr3 2 MagVader 350 Scroller m2 - Shutter m3 - Fan off; MV350
    Licht Technik MagVader 350 Scrl2 Shtr3 Fan 3 MagVader 350 Scroller m2 - Shutter m3 - Fan on; MV350
    Licht Technik MagVader 350 02 Scrl0 Shtr0 4 MagVader 350-02 Scroller m0 - Shutter m0 - Fan off
    Licht Technik MagVader 350 02 Scrl0 Shtr0 Fan 5 MagVader 350-02 Scroller m0 - Shutter m0 - Fan on
    Licht Technik MagVader 350 02 Scrl0 Shtr1 4 MagVader 350-02 Scroller m0 - Shutter m1 - Fan off
    Licht Technik MagVader 350 02 Scrl0 Shtr1 Fan 5 MagVader 350-02 Scroller m0 - Shutter m1 - Fan on
    Licht Technik MagVader 350 02 Scrl0 Shtr2 4 MagVader 350-02 Scroller m0 - Shutter m2 - Fan off
    Licht Technik MagVader 350 02 Scrl0 Shtr2 Fan 5 MagVader 350-02 Scroller m0 - Shutter m2 - Fan on
    Licht Technik MagVader 350 02 Scrl0 Shtr3 3 MagVader 350-02 Scroller m0 - Shutter m3 - Fan off
    Licht Technik MagVader 350 02 Scrl0 Shtr3 Fan 4 MagVader 350-02 Scroller m0 - Shutter m3 - Fan on
    Licht Technik MagVader 350 02 Scrl1 Shtr0 4 MagVader 350-02 Scroller m1 - Shutter m0 - Fan off
    Licht Technik MagVader 350 02 Scrl1 Shtr0 Fan 5 MagVader 350-02 Scroller m1 - Shutter m0 - Fan on
    Licht Technik MagVader 350 02 Scrl1 Shtr1 4 MagVader 350-02 Scroller m1 - Shutter m1 - Fan off
    Licht Technik MagVader 350 02 Scrl1 Shtr1 Fan 5 MagVader 350-02 Scroller m1 - Shutter m1 - Fan on
    Licht Technik MagVader 350 02 Scrl1 Shtr2 4 MagVader 350-02 Scroller m1 - Shutter m2 - Fan off
    Licht Technik MagVader 350 02 Scrl1 Shtr2 Fan 5 MagVader 350-02 Scroller m1 - Shutter m2 - Fan on
    Licht Technik MagVader 350 02 Scrl1 Shtr3 3 MagVader 350-02 Scroller m1 - Shutter m3 - Fan off
    Licht Technik MagVader 350 02 Scrl1 Shtr3 Fan 4 MagVader 350-02 Scroller m1 - Shutter m3 - Fan on
    Licht Technik MagVader 350 02 Scrl2 Shtr0 3 MagVader 350-02 Scroller m2 - Shutter m0 - Fan off
    Licht Technik MagVader 350 02 Scrl2 Shtr0 Fan 4 MagVader 350-02 Scroller m2 - Shutter m0 - Fan on
    Licht Technik MagVader 350 02 Scrl2 Shtr1 3 MagVader 350-02 Scroller m2 - Shutter m1 - Fan off
    Licht Technik MagVader 350 02 Scrl2 Shtr1 Fan 4 MagVader 350-02 Scroller m2 - Shutter m1 - Fan on
    Licht Technik MagVader 350 02 Scrl2 Shtr2 3 MagVader 350-02 Scroller m2 - Shutter m2 - Fan off
    Licht Technik MagVader 350 02 Scrl2 Shtr2 Fan 4 MagVader 350-02 Scroller m2 - Shutter m2 - Fan on
    Licht Technik MagVader 350 02 Scrl2 Shtr3 2 MagVader 350-02 Scroller m2 - Shutter m3 - Fan off
    Licht Technik MagVader 350 02 Scrl2 Shtr3 Fan 3 MagVader 350-02 Scroller m2 - Shutter m3 - Fan on
    Licht Technik MagVader 430 Scrl0 Shtr0 4 MagVader 430 Scroller m0 - Shutter m0 - Fan off; MV430
    Licht Technik MagVader 430 Scrl0 Shtr0 Fan 5 MagVader 430 Scroller m0 - Shutter m0 - Fan on; MV430
    Licht Technik MagVader 430 Scrl0 Shtr1 4 MagVader 430 Scroller m0 - Shutter m1 - Fan off; MV430
    Licht Technik MagVader 430 Scrl0 Shtr1 Fan 5 MagVader 430 Scroller m0 - Shutter m1 - Fan on; MV430
    Licht Technik MagVader 430 Scrl0 Shtr2 4 MagVader 430 Scroller m0 - Shutter m2 - Fan off; MV430
    Licht Technik MagVader 430 Scrl0 Shtr2 Fan 5 MagVader 430 Scroller m0 - Shutter m2 - Fan on; MV430
    Licht Technik MagVader 430 Scrl0 Shtr3 3 MagVader 430 Scroller m0 - Shutter m3 - Fan off; MV430
    Licht Technik MagVader 430 Scrl0 Shtr3 Fan 4 MagVader 430 Scroller m0 - Shutter m3 - Fan on; MV430
    Licht Technik MagVader 430 Scrl1 Shtr0 4 MagVader 430 Scroller m1 - Shutter m0 - Fan off; MV430
    Licht Technik MagVader 430 Scrl1 Shtr0 Fan 5 MagVader 430 Scroller m1 - Shutter m0 - Fan on; MV430
    Licht Technik MagVader 430 Scrl1 Shtr1 4 MagVader 430 Scroller m1 - Shutter m1 - Fan off; MV430
    Licht Technik MagVader 430 Scrl1 Shtr1 Fan 5 MagVader 430 Scroller m1 - Shutter m1 - Fan on; MV430
    Licht Technik MagVader 430 Scrl1 Shtr2 4 MagVader 430 Scroller m1 - Shutter m2 - Fan off; MV430
    Licht Technik MagVader 430 Scrl1 Shtr2 Fan 5 MagVader 430 Scroller m1 - Shutter m2 - Fan on; MV430
    Licht Technik MagVader 430 Scrl1 Shtr3 3 MagVader 430 Scroller m1 - Shutter m3 - Fan off; MV430
    Licht Technik MagVader 430 Scrl1 Shtr3 Fan 4 MagVader 430 Scroller m1 - Shutter m3 - Fan on; MV430
    Licht Technik MagVader 430 Scrl2 Shtr0 3 MagVader 430 Scroller m2 - Shutter m0 - Fan off; MV430
    Licht Technik MagVader 430 Scrl2 Shtr0 Fan 4 MagVader 430 Scroller m2 - Shutter m0 - Fan on; MV430
    Licht Technik MagVader 430 Scrl2 Shtr1 3 MagVader 430 Scroller m2 - Shutter m1 - Fan off; MV430
    Licht Technik MagVader 430 Scrl2 Shtr1 Fan 4 MagVader 430 Scroller m2 - Shutter m1 - Fan on; MV430
    Licht Technik MagVader 430 Scrl2 Shtr2 3 MagVader 430 Scroller m2 - Shutter m2 - Fan off; MV430
    Licht Technik MagVader 430 Scrl2 Shtr2 Fan 4 MagVader 430 Scroller m2 - Shutter m2 - Fan on; MV430
    Licht Technik MagVader 430 Scrl2 Shtr3 2 MagVader 430 Scroller m2 - Shutter m3 - Fan off; MV430
    Licht Technik MagVader 430 Scrl2 Shtr3 Fan
  • Hi Mathilda,
    It appears that there are several versions on the MagVader profile in current Eos software, however I'm unsure which profile/mode you are using specifically. In reference to page 38 of the linked manual, the DMX ranges for the fan parameter range from 0-255 (0% to 100%) but a home value other than 0 is not specified. Is the main issue with this profile the user defined values (0% to 11%) in ML controls or the lack of control of the fan?
    Best,
    Therese
  • Hello Therese,
    in total it is the profile definition. As you mentioned, it is only allowing 0-11%
    That is not making any sense at all.
    Making it 0-100% is working fine.
    And there is no home Value. Because you can define a hard value. But a Home of 0 is fine.
  • Understood! I will see if we can get this change made in the upcoming software release.
