Automark + Follow/Hang
If you use automark, but also have a few cues that use follow or hang, the moving lights in those cues will not be properly marked. I cannot mark a cue manually when automark is on. I would like to see this restriction removed.
This way you can choose to mark for a certain cue earlier (in a not-so solent part of the show for instance) or overcome the problem I describe above.
