We have a ELE1 on loan while our ELE2 goes in for repair. On that unit we pressed {Power} and then [Select] for a tidy shutdown from the keyboard. But the ELE1 doesn't seem to recognize that sequence. I have to get this over to the theater PDQ
On Element 1 (If Win 7 based) you have to shut down using the 'Exit' in the CIA (below 'File') , then 'Shutdown' on the screen that eventually appears.
When you get your Element 2 back you can just push the power button, wait a couple of seconds, then push the power button a second time to shut down.
Depending in hardware version of the Element 1 (there were different iterations of it) the button press doesn't work. In the Browser you find the Shutdown command
OK, thanks for the reply. That bit about the double power press on the ELE2 was new to me (we use Power then Select). In the meantime we'll use the CIA/File Manager "Shutdown Device Line" for ELE1. ETC loaded this with same version of software so our show file loaded fine and is up and running Thanks again
