BUG: Power Off via Macro at Noamd 2.8.3 Build 11
Quit Confirm_Comand
or
Clear Comandline [ENTER] Power Off [ENTER] Macro wait 1[ENTER
gives me -after fire this macro and then try restart- an instant Shut down
The Nomand shut down via macro like i want.
But then i can`t restart Nomad.
The Software shuts down immediately after open the EOS Screen.
For get in i must permanent "drum" at ESC on my keyboard.
This not ever happen.
But in 8 of 10 cases.
Macros works in foreground
  • Does the shell launch, but not the software?  OR no shell?
    Do you have a startup macro assigned also?
  • The shell starts.
    And if try then start the software it close instant.
    Nope, have no startup Macro.
    I not know if it is the same on a console.
    Not have test it.
    On the PC i have Win10.
  • Ah,...forgotten.
    Dosen`t matter if i try start Client, Offline, Offline with VZ.
    (Have at this machine no Dongle connect)
  • One step more done...
    What i have change yesterday was my screens-monitors.
    But the EOS Nomand not runs during change.
    Normal, PC down, unplug the old monitor, connect the new, start win10, start EOS Nomad, FAULT...
    Now i have uninstall/repair the EOS PC Software and it seems it works normal.
  • Nope.
    The second PC not runs.
    Uninstall the EOS, new install and after program a short show i get back in my neverending circle...
    The Setup via Shell i can open normal.
    But all other otptions not.
    This PC have an Dongle.
  • Can you please share your show file?
  • There doesn't appear to be a macro with that text in the provided show file.
  • Oh yes.
    After i though it was the Macro i try program it new.
    Without the Macro.
    But thats not fixed the problem.
    If i repair EOS Nomand Software -via Systemcontrol-uninstall-repai option- runs the second PC normal.
    Then i transfer the show from my office PC to the second PC.
    At this point i get the problem.
    I have also try it with older Software 2.7.4.
    So my next step will be, create this show direct on the second PC and try then a newstart.
  • Let us know how it goes.  Loading your show file here has given my no issues on a PC.
  • I have no idea.
    Have now install Win10 new.
    But nothing change.
    If i have a patch -nothing more- in the show all is good.
    I can close and open Nomad normal.
    If i have store presets and/or macros in the same show i get the fault.
  • So, now i have install Win10 complet new.
    And i hope the issue is gone.
    Ah, i work with a Faytech Touchscreen Monitor.
    He works with a resolution 1400x900.
    Think it is a "strange" format.
    it is possible this is the reason?
    With newinstall of Win10 i have now change also the Monitor to a "normal" 1920x1080.
    Next i will program also new and try it...
  • New install of win10 is done.
    Copy the show from Office PC to Dimmercity PC (this the PC make me stress) is done
    With Dimmercity PC i use now the normal 1920x1080 Non-Touch Monitor.
    Safe show on this PC, Newstart, all works.
    Now at Dimmercity runs 2.8.2 Build 8
    Tomorrow i will try what happen if i conect the Faytech Touchmonitor again.
    So i think, it is possible i get a driver problem at win10.
    Ane the newinstall fixed it now.
  • Tada,... i find it out...
    If i close Nomad via EXIT a few seconds later the Shell popup for restart Nomad.
    But....if this PopUp come you must wait 20-30 seconds before you can start Nomad new.
    Shell-Setup works instant.
    So it is a "Time Out" for restart
