Just a quick question where the Eos software can I find the current output count
clear command line, About. it shows you the output count for the whole system (i.e. the lower value of Master and Backup if you're in multiconsole).
if you're in multiconsole and want to check what output count your local machine could do if not connected to a master/backup you can open the Diagnositig tab (Tab 99). there's a line that says e.g. System 2048 Local 16384.
