Feature Request: Scroller stick to color
When I select two fixtures with different color strings and select a color with the quick access button, Eos will jump to the color, that is on the same position on the other color string.
Example
Fixture 1: Lee200, Lee201, Lee202, Lee204
Fixture 2: Lee200, Lee202, Lee204, Lee205
When I select both fixtures and select color "Lee202", fixture 1 will select Lee202, fixture 2 will select Lee204, because it is on the same position on the string. Eos should select the same color, no matter where it is on the color string.
Slight smile
