1. Cue Selection based on Labels. Possibly as an extension of the query function. example, [Query] {Blackout} {is} {cue} {Label} [enter]
2. Use offset with cue selection. Example, want to select all cues with a .5 value assuming cues are 1, 1.5, 2... Example, [cue] [1] [thru] [5] [0] [offset] [.][5] would select cues 1.5, 2.5, 3.5, 4.5...
3. Assign dimmer channel to fader without using a submaster.
