Hello, does anyone know if it is possible to import a DWG file into Augment3d please? I've only seen the Vectorworks files be imported and when I've tried to import a DWG the EOS system doesn't read the file location. Thanks for any help.
I would check this list, but assuming by your use of DWG you're working AutoCAD in which case you'll want to go with "DAE files, also known as Collada files, are the optimal export format for Augment3d from AutoCAD and Vectorworks"
https://support.etcconnect.com/ETC/Consoles/Augment3d/3D_File_Formats_Compatible_with_Augment3d
and just to clarify: you can't import vectorworks files. you can import patch data with the vwx plugin and you can import 3D data after exporting to a 3D file format like collada. both dwg and vwx are proprietary and binary files and can't be imported directly into Eos.
