Would love to be able to turn on a focuslight om the back of the fixture. Like you can on a S4LED.
it's a tiny bit more complicated than with a S4 LED, but i think you can switch the ColorSource Spot from DMX control to a preset, focus and then switch it back to a DMX.
Hey Ueli.
Thanks for quick answer.
But I am not sure you are right.
If the fixture recieves DMX I can´t do anything on the presetbutton.
If I disconnect the DMX and press preset on the first fixture, all connected fixtures light up in that preset.
But if you know a workaround, I´m very interested.
ah, you're probably right. sorry i didn't fully think this through. unplugging DMX in and DMX through and then setting the preset is a bit of a hassle when doing it with more than one or two lights.
Eksately! I have no use for the master/slave-thing but but a lot of use for a focusbutton.
Maybe somebody some day will make a new software with that solution.......:-)
