Capture Polar solo licence and hog 4 v.2.0.3 problem no Connection Artnet
i have Capture Polar on Mac Pro and Hog 4 PC on different computer, on The Sto arrivando! e Macintosh I have a N Catalyst and Work right with artnet, but The visualizer I can't can some odi help me?
Hog 4PC will only output artnet if you have a widget attached, do you have a widget attached and mapped? Do you have your IP setting correct within Capture Polar? Do you have your ArtNet and Subnet set correctly?
