I tried this option: Hog pc start window>settings>net number 1 and port 6600 Control panel>hog net>use default ip address> enable DHCP server and boot server hog pc automatically swtch to Use custom ip settings>apply Dp8000(I used hognet output and the same net/port number as hog pc )>network>console>console link config>set DHCP off>set ip 172.31.0.001 and mask 255.255.0.0 Then I connect it with ethernet of course and start new show. But this settings did not lead to the result. Devices see the network, but dp8000 displays ''connecting...'' without result((
