Hi guys about to run a larger show with about 600 RGB pixels + 200 odd fittings
Using Full size H4.
running latest version and 2 x DP8Ks 1 x black one 1 x blue one taking half the load each...
at the moment i have turned off the internal DP8ks as i know they are not real DP8ks as they run from the internal USBs
and both of the DP8ks are spitting out 16 universes of Artnet. (unicast)
i did a load test over all the fittings using the FX engine to test the DP8Ks
Rainbow effect plus pan and tilt all fanned out
but found it was the console actually capping, causing lots of Lag over any key command and in the end crashing and corrupting the show file (had a backup so no issues there).
i know i wont be going to this level of programming but just wondering if there is any thing i can do to help this
i will have another full size plus a RH4 in the network for the show but didn't for the test
the DP8ks were only at about 20% load when i did the load test that is why im think its console related
i do have some custom fixtures in the show apart from that nothing else really out of the ordinary
is there any advantage in running the internal DP8ks?? or best to keep them out of the loop..
Hognet is running in 192.168.1.1 range
Artnet in 2.0.0.1 range
only had pallets open no plots..
