Input and Output Connections From right to left when viewing the console from the back: Mains in: IEC 320 connector (5A/250V rated cable supplied) 90-250V, 50/60Hz, 2A maximum 1 x 5x20mm 5A T fuse MIDI in,out,thru: Musical Instrument Digital Interface input, output, and thru ports LTC In: 3-pin XLR Linear Timecode Input DVI out: 3 x DVI-I single link female connectors Ethernet: 2 x Neutrik Ethercon; Gigabit Ethernet port USB: Universal Serial Bus 2.0 ports (6 rear, 1 inside front utility tray, 1 inside armrest) DMX out: 8 x Neutrik 5 pin female XLR Galvanized Isolated Keyboard: Built-in Miniature QWERTY keyboard
Power, Weight and Dimensions Power: 300W Weight: 75 lbs (34 kg) Dimensions with Screen Down: 40.5” wide x 28.49” (723.7mm) deep x 6.49” (164.75mm) high Dimensions with Screen Up: 40.5” (1028.7mm) wide x 28.49” (723.7mm) deep x 16.43” (417.39mm) high
