Hog4 PC in Nano Mode cant do straight record of a view
I cant seem to hold the record key and record or rerecord a view in Nano mode by hold record and hitting the view number. I have to do the actual command line sequence record_view_#. Its a fine work around but thought I'd mention it.
Confirmed.. On my end as well. There is some funky inconsistent stuff happenin with the View system.
The other workaround is to press "record" then press a field in the view palette.
You will also find that sometimes on the PC4 in nano mode that even pressing the soft view keys in the toolbar will not snap to the selected view. The workaround is to select an empty group pallete, then the view toolbar will work.
