v1.1.2 b339 Color mixing doesn't relation selected from kind button
Hog4 and Hog4 PC v1.1.2 b339
Patch fixtures these are having color mixing and LED(RGB).
Select fixture and Select color mixing(CMY) parameter by Colour Key.
Touch Cyan wheel, you could see 0% on Magenta and Yellow as touched value.
Clear all color value.
Do something, But select color parameter by Colour Mixing Key on Kind Key or button.
Touch Cyan wheel, you couldn't see any value on Magenta or Yellow.
I tough, These tow method should have same result.
And CMY parameters should relation all time.
You can knockout each parameter, If you want.
And These behavior is also occur on Intensity key and RGB intensity key on Kind button.
Aki
