Hi Guys
I have two lists running on fader. One running form master 2, the other one from master 3.
None of master 2 or 3 is chosen.
When i hit the release key+choose - from master 2 - the list on master 2 is not released. But master 2 is chosen now.
Same for the other list running from master 3.
So the release button ONLY works when i predefine a chosen master?
from the manual:
Releasing Masters
You can remove a cuelist's look from the stage, so that it relinquishes control of all fixture
parameters and effectively turns the cuelist's output off; this is known as releasing the cuelist. To release a cuelist on a master:
• Release : releases the currently chosen master. Or:
• Release + Choose : use the Choose key of the master with the cuelist you wish to release.
other question:
when running a list not from a master but from the list view (by pushing the tile) how to release a list there?
Jay
edit:
ok i got it!!!! its just the order of pressing keys. so the manual should point that out that you have to push Choose+Release instead of Release+Choose.
Thanks anyway
