Whats the resolution of the H4 screens? What about the wings? Just trying to determine the size of an external. What is the max wide screen resolution supported on the DVI's in the desk (as to NOT slow down the desk like the H3 did)
no need to worry about slowing down the console. The H4 has 3 dedicated graphic-adapters from ATI, also enough resources in RAM and Processor power. Compared to the H3 with 256MB of RAM and now 8GB and a board and OS designed to run with 4GB RAM there is enough power left for the displays. But I also dont know the max. resolution. I used 1920x1080 without any problems. Dont know if 2560x1600 will work.... I think it will, cause even older graphic adapters support these resolutions. Couldnt find out yet which ATO modell is used in the H4 in the RH4 it is the ATI FirePro2460 (when I remember it correct), the FirePro candle handle max resolution 2560x1600
