This might be a silly question but where is the tab to print ? I can see the preview page but where do you go from there ? Hog4 4 PC ? I just want to print the patch ?
You can create a PDF, which you then can print from your preffered PDF-App. The PDF is created when you click the printer icon in the patch or any other directory Adjust your settings and then click save and select the location where it should be stored
