But for real pixel-mapping i would never use a console I go for a media-server, cause i like to do more than just play back a bitmap or small image Most of the stuff can be done with buddying, grouping, and fanned-timing
With complex, distributed systems like HOG-Networks or also other brands, it is not so easy to do a good pixelmapping-setup. You need to transfer all your files first to your network-nodes. Cause all calculations are done in the nodes. Systems like Clarity only output artnet from the console and have no distributed calculation processes. So it is easier for them. If you like to transfer movies in a short time to the nodes you need a GBit Network to have it done. Also you must limit the file size and so on... All limits I dont like when I do pixelmapping... So lets stay with a mediaserver
