I'm trying to create slotted color effects using the new engine parameters. When I apply a sine for example to my slotted color wheel, nothing happens. At all. Also when I try and adjust effect begins, effect end and effect start, all the wheels are toggled to white slot and will not move or change. I still have a problem with with my nano from previous versions that is unresolved where the encoder wheels will not change the value of a fixtures color. The only way I can change color is with the tool bar. I suspect this new problem could be related to the old problem.
Michael, the new begin, end, and start values in the effects engine are not support for slotted functions but you should still be able to build slotted effects regardless.
If the fixture you are dealing with doesn't have an offset for the slot you are putting the effect on then make sure the effect size is 100% or larger because that is the size required to result in a single slot value change on each side.
