Permissions palettes
hello,
I find the "palette permissions" not very practical.
The principle is not bad, it's good to tell in the position directory what is allow are not by default..
If you have to record X palettes with positions and beam, it's cool to not have to choose a mask each time.
But in the cases where I record only the positions and I want exceptionnally record a gobo in position directory, I have to open the position directory configuration window, accept beam, apply, record my gobo, re-open the position directory configuration window, uncheck beam and apply to return to normal.
Do not you find it a bit "heavy" as manipulation?
Before, we just had to do "use B" and record palette ... I think it is much faster and therefore more simple.
So it would be good to keep the "permissions" on directory, but please let us be able to record a beam in position directory by using mask if the default beams are not checked ...
What do you think about that?
Regards,
Gaël
