Hi there,
Had a serious problem when trying to build and effect off palette for my colorados;
Selected colorados [21 through enter] went into fx engine and set table to [stop] then recorded an effect.
Open + FX: all the colorados would be recorded having a [stop] table except for fixture (21) (It was not even present in the list). Tried repeating process a dozen times, with various filters. Tried editing the FX internally and updating, still would not take the effect.
The only workaround is I patched a ghost fixture of a different type so the board would default a 'global' palette to add the fixture, even then it was messy inside and had to edit internally and update.
