[BUG] Incorrect palette displayed in Output Window
Full Boar and Hog PC 2.1.2
Output Window "Show Palettes" ON
Record P/T parameters on Position palette. Label 'Drums'.
Select fixture, use 'Drums' Palette. Record new Position palette 'Band'.
In Programmer Window, fixture will show that it's in 'Band' palette but in Output Window it shows 'Drums'.
This is the same when recorded as a 'Allow Refs' or 'Direct' palette.
Also happens with Beam palettes.
