ANOTHER SIMPLE NEWB QUESTION
Say i want to loop cues 4-8 on fader 2and skip the others??
lastly the command line for moving cues from one fader to another
say fader 2 cue 5 to fader 6 cue 7??
thanks again in advance!!!
  • Hello Brian,
    In order to do this you will need to insert what we call a Link Cue.
    Open the list (list X open) and goto cue 8 then hit the Insert Link button.
    This will insert a Link Cue after cue 8.
    Under the Fade column you will see Cue 1, Highlight the cell and hit set 4 enter. It should now read Cue 4. This is telling our system to jump back to cue 4.
    Under the Delay column you see Forever, if you want you can change this so it will only play the 'linked' cues X amount of times.
    In order to copy cues and paste them into another list:
    List X Cue X Copy List X Cue X Enter.
    Please keep in mind that we will ONLY copy the information within the cue, we will NOT copy the tracking values.
    Hope this helps.
