Changing Fader values
I am sure there is a trick to this but so far I have not found it.
I record dimmer values on a fader that is on a page
I change page, same place (fader 10) is the 5600k stage wash
this fader is set to remember values
But if I change this fader up or down it dose not change when the page is played
once more it stays as it was before.
Is there a way to get is to remember the change I made ?
there must be.
Parents
  • Robin, I think I got your problem, capture activity is overruling remember fader values.
    If you have a look at your page directory, change to spreadsheetview, there you will see the macro that is executed when going to that page.
    I think you have a FMx/x macro for your master 10 there, so thats why your faders are not responding in the way you expect it.
    Delete the FMx/x macro and you get what you want
Reply
Children
No Data
