Hi All,
A bit of background first I'm an experienced Hog 2 programmer who has spent the past 5-6 years programming Grand MAs and now I'm going back to the program some Hog 4s.
The rig I'm programming has a mix of GLP Volkslicht ( similar to a Mac 101 ) , Ma700 profile, Mac 700 washes, and Mac 301's
I'm having issues recording color palettes. I select all the fixtures and dial in a color ( for this example magenta & yellow to make a Red ) and then record it to a color pallette and replay it The MAc 700 profiles go Red , The Mac 301's are pink/magenta and the Volks and mac 700 washes are white.
This behaviour happens on the console and Hog 4 PC.
On every other console I have used when you record a palette it records every thing you see.
I can get it to work if I record and merge each of the parameters together individually or use the "record type" function on the tool bar that becomes visible when you hit record.
Am I missing something, or is this sort sort of character that is meant to enhance my programming technique
Thanks in advance
