Lists remembering fader values when they shouldn't
Hello,
I first noticed this with v2.6.0 but may have been present before.
If I remove a List from a Master, the fader level is "remembered" if the List receives a Go command from a Comment Macro. Only if I manually trigger the List from the List directory does the virtual fader return to 100%. This is with "Remember Fader Values" turned off.
All behaves as expected when Remember Fader Values is on.
Cheers
Colin
