After installing the PC Version of 3.0, I no longer can connect to the visualizer. Status says: Connecting, Session:No Server. This does not change whether I am connected with an actual console or HogPC on the same PC as WYG. I also do not see the visualizer in the network pane. Port numbers are all the same and HogPC and My FUllboar see each other.
Has the console downloaded a copy of the DP yet? To find out look at the top of the connectivity box that shows up at the bottom right of the screen. Does the toolbar handle (top of the window) show a build number (972 or 1056)?
I have same problem here ... HogConnect 3.0.0 not stable always disconnects and 3.0.1 doesn't connect at all. Also Hog4 v3.0.1 software has a bug I think in which Hognet Port and FixtureNet port seem to be flipped ... I usually connect to Arkaos Media Server thru fixture net in versions 3.0.0 and earlier but in 3.0.1 artnet is transmitting on hognet port.
