I've just loaded H4 pc into surface pro 3 and its the smallest format I have seen !! cant use Ctrl + to zoom in though it works with every other program and the primary and secondary screens are opposite to the show its connected to !! any one know how to sort this issue ?
its not the number of screens its the extra small size !! even with decreasing resolution of screen the button are still about 4mm square and I don't know anyone with fingers that small
I always go into the display settings on the Surface Pro and the select make Text and Other Items larger, then set that to max, logout then launch HogPC
