Library Robe DL4S
Just played around with a Hog 4 and the Robe DL4 series.
I noticed there is a mistake in de the DL4S library file.
The CMY colors go from 65535>0.
With the fixture in CMY-mode, the control is RGB, when set into RGBW mode, the control is CMY + White.
When setting the CMY DMX-values at 0>65535 and the fixture in CMY, everything works correct.
The DL4X & DL4F also use these values and work correct.
I have used Mode 1 for all fixtures.
best,
Pim
