Fade changes issue
Quick question: at a show on hedgehog. Have groups selected and changing colors with pallets. Fade changes is on. Yesterday the pallets were fading when I would select. Today they aren't. I've already cleared the programmer and pig released. Any ideas on what I'm missing??
  • A couple of possibilities. If you are changing colors on a color wheel vs a color mixing system such as CMY or RGB for example, color wheels do not observe the time.
    It is possible the default timing has been changed as well. Look in the Timing tab of the Preferences window and confirm the Fade isn't set to 0 for everything.
    After selecting the fixtures try pressing COLOR X ENTER. X being the fade time in seconds, see if this helps.
