Start a new show and patch 36 channels.
Set your repeat to 6 repeats.
Fixture 1 thru at 20 thru full thru 20 enter.
Instead of having fixture 1 and 6 at 20, fixtures 2 and 5 at 60 and fixture 3 and 4 at 100 (and this pattern being spread across my selection)
I have fixture 1 and 11 at 20 and fixture 6 at 100 and remaining fixtures between 2 and 10 proportionally increasing towards 100.
Same pattern repeated every 11 fixtures
It looks like repeat sets the centre fixture and fixtures around it rather than the right amount of fixtures the fanned values should be spread among.
This is true for every parameter and time as well.
It works fine with x thru y fanning mode. it works fine with buddying both with x thru y and x thru y thru x.
Off topic: looks like I can't give the step table any Begin, End and Start value anymore in the effect engine window.
Thanks a lot
