Fixture profile issue: Elation E Spot III Extended
The profile for the Elation E Spot LED III (extended) fixture has a couple issues:
1. Missing Frost filter
2. Gobo wheel rotation is not defined correctly, so what the fixture does is not consistent with what the Hog UI indicates.
I looked at the existing profile and it appears to be an easy fix; it should be fixed in the standard library, however, as (right now) it takes functionality away from the fixture.
Fixture DMX reference is here: cdb.s3.amazonaws.com/ItemRelatedFiles/9809/elation__E_SPOT_III_dmx_traits_ver_1.pdf
See channel 10 (Extended) for the Frost filter value and channel 7 (Extended) for the correct gobo wheel CW/CCW rotation values.
Cheers,
-kbx
