In order to open the windows menu on Hog Consoles: Press and hold for 2 seconds, or double click. (according to manual 2.2.1)
'Press and hold' works everytime, but 'double click' doesn't work every time. Seems like if the mouse is already on the screen you tap, that a double tap will fail (tried slow and fast tap speeds). If I move the mouse to the other left monitor and then double tap right monitor it has a better success rate.
-Both methods succeed every time on Hog PC logged into same show
-New show file. Mouse Pointer Sensitivity is in default position = medium speed
-default user logged in, no other users created in this show.
