The default position (0 at pan and 0 at tilt on RH4) of my moving head is not parallel with the base.
Is there anyway I can offset the position of this moving head so that it is parallel with the base?
Would i able to edit the fixture library? (creating a cue for permanent solution is not ideal)
Thanks again for any input. =)
