After updating console software to 3.8.0, my front panel is being recognized as a Nano wing instead of the native Hog front panel. Faders only work if set up as a wing in control panel. Is there a fix for this?
Try to update to v3.10 If it still shows up as a Nano, check the dip-switch settings on the PCB Cant remember exactly which one selects if its a nano or a RH frontpanel. As the PCBs of the Nano and RH4 are the same and the DIP Switch settings defines what it is. Similiar to the widgets (internal/external)
