When you update a directory using update the Effects tab is always blue even though you have not adjusted any Effects. I am in additive mode. This should not happen, only adjusted ( touched ) parameters should come on to record. this is a massive problem as you can get the off Effect into directories on a few fixtures which causes all sorts of problems when trying to turn off effects in cues. This has been a problem for a long time now, please fix. Thanks
