3.13.0 - build 2862
1 x RH4 + 1 x DP8000
When using VIEW BY DP on the Patch View for the External DP... and then UNPATCH SELECTED UNIVERSE... followed by APPLY PATCH.... the DP's Universe still outputs the original patch data (or doesn't clear it to zero).
When using VIEW BY DP on the Patch View for the External DP... and then UNPATCH @ to remove a dmx address from a desk-channel patched to multiple DMX addresses.. .it doesn't remove that channel from the output.... even if you APPLY PATCH, and/or close the Patch window.
FIX > opening the Network Window, right-clicking on the External DP8000 and clicking on RESET NODE, fixes the problem.
D
