Wait times issue
So here’s a thing.
Last year I programmed a show in 3.9.0.
I had one very complicated track to run, and had no timecode. I ran the cue list with Learn Timing to record Wait times, so I just had to hit go at the start and the whole track ran from that. It worked perfectly.
The other day I did the same show, so I used the same show file, but now on 3.12. The timing is now slow. By the time I’m halfway through the track the list is running noticeably behind. It’s the same track, the only thing that’s changed is the software version. I had to re-record all the wait times.
Parents
  • Not sure if this has any relevance in your scenario.
    I had a situation running a show with timings created through learn timing. We was in a sweltering hot venue and had 2 desks networked together and the list would go out of whack with times as the list progressed.
    We would run again and it would be fine, the next audience would come in and it would go out again. We just put it down to heat at the time.
Reply
Children
No Data
