Is it even possible to get Time Only pallets working properly with Lists set to Cue Only? Without programming the used fixtures in every single cue. I cant get it working properly.
When the Time Only pallet is replaced by a new time, it doesnt apply to the release/"fade out" time, only to the Fade In of the cue.
When opening the List the Fade tab of cue 1 states 1s,3s.
Where 1s is refering to a BUMP Time only pallet. And 3s is refering to a default fade time. As shown when opening a cue, 3s is no where to be found. But it seems to be the release time for parameters and fixtures not used in the next cue.
I hope i explained it well enough,
Someone who faced this as well and found a solution?
