just downloaded 3.13 for pc and my widget on my hoglet isn't outputting dmx. i downgraded back to 3.10 it worked. really would hope this would get fixed so i don't have a whole crew waiting for the fixture library for 3.10 to load so we can go home.
Hello, the widget may need to be remapped, try the following. Open the Network window, SETUP->NETWORK. Right click on the DP8000 and select SETTINGS. In the new window select the DMX Widgets tab. In the first 4 pop down boxes, select NONE and press OK at the bottom of the window. The window will close. Close the Network window. Re-open the Network window, Right click on the DP8000 and select SETTINGS, In the new window select the DMX Widgets tab and reselect the widget number in the four top pop down boxes. Press OK.
