3.13 continuous color bug
Using 3.13 and try the following:
-Patch 1 Ayrton Khamsin Standart and select
-hit .+fixture
-set a half color using the encoder for continuous color
- record a list
-select the khamsin and edit any attribute and merge to that cue
-hit clear
You see the color wheel snaps to a value that is a actually outputting.
You need to re-run the cue to make the half color visible again.
This happend to me on a show today while updating stuff. Even just changing fade times in the list view snaps the half color to red.
Even while updating other fixtures make the fixtures with half color go crazy.
Cheers
J
