MIDI input not working
I must be missing something, but I can't figure out what exactly. Here's what I've got going on.
I am using a launchpad pro (not the new MK3) hooked up VIA USB directly to a Roadhog 4 with 3.13.1 (b2885) on it.
The launchpad is set up into drum mode, channel 1, MIDI out: ON
In the hogs MIDI configuration page: (device 1) > Device ID: 1, Device Group ID 112, MSC in/out (off), MIDI notes in/out (on)
MIDI note input: (MIDI channel 1) > Comment Macros
I've set every midi note to "GL1" which is just a simple intensity cue to test
And I get nothing... What am I missing here?
As a side note, I've hooked the launchpad up to bomes and confirmed the drum mode is sending out the correct CC notes. I must be missing a check box or something I'm guessing.
