BUG - 3.15.1 DP needs to be deleted and recreated to change universe output
On Hog4PC 3.15.1 (b3142) no changes to the output of the Processor will take effect after the first time the mapping is assigned. For example, if you create the initial map with just U1 outputting, accept, then attempt to add additional outputs, they will appear but will not actually function, even though the DMX window says that they are. The Processor must be deleted and a new map of everything you want created before hitting accept. This happens with a hardware DP8000, the Hoglet4, and the Nomad 6144 output key.
Hi, Is it possible that the show you are using was created in an older software revision? I've seen this issue previously where the DP shows up in the network settings as a DP 8000 rather than processor which I believe is correct? Removing the DP8k and then adding again creates a processor which I'm presuming incldues the HPU range.
