Show server init failure.... Again!!!!
Hi
I get this message only when I try to create new show.
Show that I created yesterday, opens normally!!!
Any suggestions?
  • So it just doesnt want to start a new show!!!!
    I uninstall and reinstall the software and still does the same.
    Opens older shows but cannot create new one!!
    Any help?
  • Hello. What console and version is this occurring on? And is this console on a network with other consoles or by itself? Thank you.
  • it is just this HogPC. Nothing else in network!
    The latest version is installed, and it was the same version that previous shows were created
  • Ok, a few more questions. What version are you using? Do you have any wings (such as a Hoglet) attached to your PC? Have you verified your Firewall is turned off? Thank you.
  • Yes there is an miniWing4 and a DMX widjet.
    Firewall is off and the version is 3.17.1
    Thanks for your help anyway
  • Ok... now, after a lot of tests....
    At windows settings, network settings, there is this " network reset"
    When I press that, I can start a new show normally!!
    But this procedure requires to restart the PC. After the restart I cant start new show!!! But the show that was created between, network reset and restarting the PC, opens normally!!!!!
    Now what about that?
  • That sounds like you have something on your network preventing you from creating a new show file. Show creation pulls more resources than opening a show. If you only are using WiFi, try creating a show disconnected from WiFi; if connected to a network via Ethernet, disconnect the ethernet cable and try creating the show.
