I have to use a hog 4 for 2 events and can still not figure out how to do the timing of a shutter or in general chases with a tap … similar to the „learn“ button knowing from licon and co
Hog has 2 different tap methods depending on whether you are looking to manipulate a chase or an effect
Tap Sync:
To adjust the rate of a chase using Tap Sync, hold down the Choose key of the master the chase is attached to, while pressing the master's Go key repeatedly to the required beat. Hog 4 OS will learn the speed of the chase from you, in a minimum of two beats; after this, you can release the Choose key.
Note that you can only use Tap Sync with chases loaded onto physical masters, not virtual ones.
Tap Tempo:
To adjust the beat rate of an effect using Tap Tempo, hold down the Choose key of the master the effect is attached to, while pressing the master's Halt key repeatedly to the required beat.
