Hi Everyone,
I want to upgrade my Roadhog 4 to the latest OS software V4.0.0 (b3673) from V3.12.0 (b2351). I made a USB flash drive and put it into the console then turn on, Console did not show me the system installation screen automatically, it go to the normal screen only.
I through I might jump over too many versions so I did try to upgrade V3.13.0 (b2862) and I get same result. I can check the contents inside that USB stick via the file browser on the console. May I launch the update process manually, or anything wrong when I use the Etcher to make that USB flash drive?
Thank you very much!
