Default Palette Naming
Hi
Is it possible to have what all the code word definitions appear right on the Default Naming page?
I tried to look it up in the manual what the codes mean and in the index, there is no entry for "Default Naming," "User Preferences->Default Naming," "Naming"
I pulled up the PDF and searched the manual and found it eventually.
(side note: how do I search the manual from the console?)
Also, is there an code that I can put in to have a group display the channel number if there is only one channel recorded?
Like "%c" for group
with Channel 375 recorded
would produce label "375"
For groups that are recorded with more than one channel, it would just default to another group name.
So I could see this implemented as
Group: enter codes
Group Single Channel: enter codes
-Ben
Parents Reply Children
No Data
