my hog pc can not work with exisiting show.. it is 339. when load from hog3.2.6 show data or exisiting show data.. the software will colose aotomatic... it is a bug ?
How are you loading your H3 show? You must be loading from a backup file, NOT a fully expanded showfile. If you try to open an expanded showfile I would not be surprized at all if this caused the software to crash.
I was loading backup file from 3.2.6.. and I already pre-write show for a while.. I can load in backup showfile..but I can't open exisiting showfile.. but something is very funny..if I change 4pc mode I can work .if I change back to nano..the software will close.. so I think that is a bug...
If you start a show in Hog4 Mode and then go into Nano mode, it may crash. This is a bug. You need to load the backup into a new showfile while in Nano mode. Did you by chance first load the showfile while not in Nano Mode?
Try Backing up the showfile in Hog4 normal mode and then create a new show file in Nano mode and use the Merge show function.
no...I start show from nano..and sometimes will auto close.. so I change to full mode ..it can work .. someone tell me to creat a new show is hog 4 file and merge my old show.. I try it today...it can work...so let check in next theatre..
