I do a lot of busking shows...
therefor my show-setup consists of a lot of virtual cuelists spread across my screens.
I also do have a lot of 'release-line' lists that release that coresponding cuelist.
Basically these are blank cues with comment macros inside.
I always find it very time consuming to store or edit these virtual lists.
Every busking list like that only contains of 1 cue.
But storing values to a list is a commandline thing.
I have to type eg: record-list 231/1 which is a lot of fingerwork for editing hundred of lists.
So i thought i could just use scenes.
Therefor editing and recording would be that easy. Just hit record and the tile and there you go.
But then i realized that you're not able to use comment macros within scenes.
Therefor i cannot use the 'release-line' cues.
I COULD mix scenes and lists, but hey.....
would be more easy to just deal with scenes.
What do you think?
